Can I cascade AP-205 From Second Port on AP-225 working in Instant Mode and what is the best configu
  • 1.  Can I cascade AP-205 From Second Port on AP-225 working in Instant Mode and what is the best configu
    Posted Mar 04, 2015 08:38 AM
    I have Location where is no network Cable
    customer wanted to add Instant AP at this area connected to the exisitng Instant Cluster
    Can i connect the new AP to nearest AP-225 from the second port
    and what is the best configuration on the wired profile
    #AP225
  • 2.  RE: Can I cascade AP-205 From Second Port on AP-225 working in Instant Mode and what is the best configu
    Posted Mar 09, 2015 08:56 AM
    It is possible to connect an AP to another AP over the wired port but , I would recommend you to bring up a mesh link in your scenario.
    for your ref :
    Step 1 : Disable extended SSID on the VC so that the Mesh functionality is enabled.
    Step 2 : join the new AP (AP225) to the existing cluster
    Step 3 : remove the AP-225 from the cluster and power up with external power supply, it will start acting as a Mesh point and it will form a Mesh link with the VC ( Mesh portal)
    Hope this will help you.
    Please feel free for any further help on this.
    #AP225
