Can I create individual user accounts on a single SSID?
  • 1.  Can I create individual user accounts on a single SSID?
    Posted Jan 16, 2012 11:53 AM
    Folks,
    Bear with me as I ask what must be for most of you a very basic wireless networking question.
    I recently installed a wireless network using a dozen Aruba 105s and I would like to limit access to the network and monitor usage - can I create individual accounts (user names / passwords) on a single SSID?
    Any suggestions is appreciated.
    Michael
  • 2.  RE: Can I create individual user accounts on a single SSID?
    Posted Jan 16, 2012 12:52 PM
    yes you can, to restrict a user you can assign the user to a role where you can assign ACL to restrict access.
  • 3.  RE: Can I create individual user accounts on a single SSID?
    Posted Jan 16, 2012 01:37 PM
    What type of authentication do you use?  Is this a pre-shared key, captive portal or do you have authentication via RADIUS?
    If you use a pre-shared key, you will have to derive a role based on MAC address or device type (DHCP fingerprint).
    If it is a user authenticated SSID (captive portal or RADIUS), then you can apply different roles based on the user ID.  You will need to add a server rule that looks at the RADIUS response or the internal DB user role.
    See the Validated Reference Guides (VRDs) at http://www.arubanetworks.com/technology/reference-design-guides/ for more info.  There is a good VRD on DHCP fingerprinting, guest access (if you are using a captive portal) and RADIUS setup (in the Mobility Controllers VRD).
