last person joined: 9 hours ago
Can I enable 802.1x + mac auth in front of radius on the same VAP?
  • 1.  Can I enable 802.1x + mac auth in front of radius on the same VAP?
    Posted Jul 01, 2012 02:40 PM
    Hi Guys,
    can I enable 802.1x + mac auth in front of radius on the same VAP?
    Is it possible.
    Config example or vrd containing the exact config will be helpful!
    Thanks in advance,
    Me.
  • 2.  RE: Can I enable 802.1x + mac auth in front of radius on the same VAP?
    Posted Jul 02, 2012 07:10 AM
    You should have a look under "Mixed Authentication Modes" in Aruba OS UG 6.1, page 323.
    There is a command in the AAA-profile called l2-auth-fail-through;
    "Use l2-auth-fail-through command to perform mixed authentication which includes both MAC and 802.1x authentication. When MAC authentication fails, enable the l2-auth-fail-through command to perform 802.1x authentication."
