Can I export the certificates stored in /flash/certmgr/serverCerts from my controller?
This thread has been viewed 19 times
  • 1.  Can I export the certificates stored in /flash/certmgr/serverCerts from my controller?
    Posted Mar 05, 2014 01:33 PM
    I have EAP-TLS terminating on a 3xxx controller and would like to migrate the installed server certificates to a new 72xx.  Any assistance would be appeciated....Thank you
    Randy
  • 2.  RE: Can I export the certificates stored in /flash/certmgr/serverCerts from my controller?
  • 3.  RE: Can I export the certificates stored in /flash/certmgr/serverCerts from my controller?
    Posted Mar 05, 2014 01:54 PM
    The certificate is in there in flashbackup, but I would assume you can't just import it into another controller, even if they had the same hostname.  You should assume you need to generate a CSR and generate another certificate.
    Hopefully someone from Aruba could clarify that.
