Can I fix the client to connect specific access point?
  • 1.  Can I fix the client to connect specific access point?
    Posted Nov 04, 2014 04:21 AM
    I have a 650 Mobility Controller with AP105. I would like to fix the wireless clients to connect the specific AP instead of it connects to any AP, is that possible? How should I go about it? My 650 Mobility Controller is on OS6.3. Please advise.
  • 2.  RE: Can I fix the client to connect specific access point?
    Posted Nov 04, 2014 05:18 AM
    What's the purpose behind this ?
  • 3.  RE: Can I fix the client to connect specific access point?
    Posted Nov 04, 2014 06:25 AM
    The deployment of the Aruba wireless is actually for wireless infrastructure for iPad as information kiosk in a shopping mall. I have found out that the iPad can't get a stable connection although is connected through 5G wireless. I have enabled ClientMatch feature and also maximize the Tx EIRP, iPad still got no stable connectivity. Please advise.
    Sent from Mike iPhone
  • 4.  RE: Can I fix the client to connect specific access point?
    Posted Nov 04, 2014 06:28 AM
    Is your network designed for 5 GHz? How far is the nearest AP?
    Cranking tx power is only going to make things worse.
  • 5.  RE: Can I fix the client to connect specific access point?
    Posted Nov 04, 2014 06:41 AM
    The network is designed with dual band 2.4G and 5G. 2.4G traffic is congested in the shopping mall. So the performance is not that ideal if connected through 2.4G.
  • 6.  RE: Can I fix the client to connect specific access point?
    Posted Nov 04, 2014 06:33 AM
    You may want to do the following:
    - If you are only supporting iPads you should consider enabling 802.11r.
    - Disable lower data rates
    - And look at the ARM min/max EIRP
    What version of AOS do you have installed ?
  • 7.  RE: Can I fix the client to connect specific access point?
    Posted Nov 04, 2014 06:39 AM
    I am on OS6.3. All the iPads are on IOS7. Maybe I will try out your suggestions. Keep posted here after I got the result. Thanks.
