Network Management
Can I generate report with old data(was delete)?
  • 1.  Can I generate report with old data(was delete)?
    Posted Jan 22, 2018 01:22 PM
    Hey Guy!
    I have a problem with airwave report!
    I have controller AOS8 added on monitor mode.
    In this time can gen any reports right?... yes!
    But I just delete devices before gen-report.
    Can I generate report with old data like i have controller still running?
    Best Regards.
    BABABA
  • 2.  RE: Can I generate report with old data(was delete)?
    Posted Jan 22, 2018 03:54 PM
    If a device is deleted from the database, then the datapoints for that device are also deleted.  You'd only have access to the data if there are historical reports that have that data (already generated reports).
    If the data was collected before the last backup point, you could restore to the backup (but it would override any data recorded since that time stamp).
  • 3.  RE: Can I generate report with old data(was delete)?
    Posted Jan 22, 2018 10:22 PM
    Hi Rob Gin,
    Thank you sir.
    I have to restore back to controller still running.
    Now report can generate!!
    Good day.
