Can I have two separate user roles for the same VLAN?
Yes. What is your use case? We can tell you how to do it.
Hospital environment with IVpumps using a VLAN 5. Pumps pretty quiet most of the time. We have a project where they are introducing Google Glasses for doctors to use. Instead of creating another VLAN and all the router configs that go along with it I would like the user role to ride on that same VLAN.
You could use a user derivation rule (udr) that looks for the first three bytes of the mac address to set the role.
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-use-the-user-derivation-rule-to-set-the-role-using-a/ta-p/182426
Thanks guys, I appreciate the help.
