Network Management
Can I install 3rd party MIBS into Airwave
  • 1.  Can I install 3rd party MIBS into Airwave
    Posted Mar 11, 2015 08:08 AM
    When adding a router/switch to our Airwave server, Airwave only supports a limited number of switches. We are an HP site with loads of the HP ProCurve switches which I can select from the list of known devices. However, i'm adding an HP rebadged H3C device (ComWare 7) and I've had to add it as a generic device.  While Airwave talks SNMPv3 to it quite happily, it doesn't recognise the H3C specific MIBS. Can I upload a set of H3C mibs to Airwave to cover this device set?
    If so, where in Airwave do I upload the MIBs?
    Rgds
    Alex
  • 2.  RE: Can I install 3rd party MIBS into Airwave
    Posted Mar 11, 2015 05:28 PM
    Not at this time.  What devices are you looking to poll from AirWave?
  • 3.  RE: Can I install 3rd party MIBS into Airwave
    Posted Mar 19, 2015 05:38 AM
    HP Comware switches which are rebadged H3C devices and therefor have their own MIB tree
    Rgds
    Alex
  • 4.  RE: Can I install 3rd party MIBS into Airwave
    Posted Mar 19, 2015 01:02 PM
    This should be 2 RFEs:
    1) feature request for allowing user to import custom 3rd party MIBs
    2) feature request for 3rd party support of HP H3C switches
    At this time, you can add the switches with the generic router/switch type under device setup -> add.  It will only gather data that's over the common MIB-2 oids.
  • 5.  RE: Can I install 3rd party MIBS into Airwave
    Posted Jun 30, 2015 12:00 PM
    We need monitor (not just ping) intefaces of other brands devices like Fortigate, Extremenetworks, Infoblox and by the way some (by WMI) windows servers.
    Please help with that be cause more the one monitor (airwave, cacti,spiceworks, etc..) server on the network is not an option isn´t?.
    Regards.
  • 6.  RE: Can I install 3rd party MIBS into Airwave
    Posted Jun 30, 2015 03:58 PM
    have you tried the generic router/switch device type and checked what info gets you then?
  • 7.  RE: Can I install 3rd party MIBS into Airwave
    Posted Oct 18, 2016 09:43 AM
    When I try to autodiscover it or manually add it, it gets rebranded an OfficeConnect switch. It can monitor CPU but I get a lot of SNMP polling errors and the interfaces are not discovered. I have 5900 and 5700s.
    Recent AMP Device Events (view system event log)
    TIME USER EVENT
    Tue Oct 18 09:39:22 2016 System Error in SNMP polling: Unknown error(interface_monitor)
    Tue Oct 18 09:35:07 2016 System Configuration verification succeeded; configuration is good
    Tue Oct 18 09:34:45 2016 System Configuration verification succeeded; configuration is good
    Tue Oct 18 09:34:20 2016 System Error in SNMP polling: Unknown error(interface_monitor)
    Tue Oct 18 09:34:10 2016 System Status changed to 'OK'
    Tue Oct 18 09:34:10 2016 System Up
    Tue Oct 18 09:33:42 2016 System Firmware changed to '7.1.045, Release 2422P01 '.
    Tue Oct 18 09:33:41 2016 System Converting from device type 'Router/Switch' to 'HPE OfficeConnect Switch'.
    Tue Oct 18 09:33:31 2016 user Configuration change submitted
    Tue Oct 18 09:33:30 2016 user Authorized
    Tue Oct 18 09:33:30 2016 user Created
  • 8.  RE: Can I install 3rd party MIBS into Airwave
    Posted Oct 18, 2016 11:36 AM
    I don't see those switch types under our supported device types.  So unfortunately unless they use the same generic MIB-II OIDs, we might not going to be able to see the port data unless device specific coding is added to map out their MIB tables.  Has a feature request been submitted yet?  That's the best route if adding generic router/switch doesn't do the trick.  Be sure to include device type, model, firmware version, and an SNMP walk of the entire OID table.  From there, the Product team will review.
  • 9.  RE: Can I install 3rd party MIBS into Airwave
    Posted Nov 06, 2017 08:14 AM
    Hello
    I have the same problem.
    I need to import MIB in AirWave.
    is it possible to do this now?
    my release is AirWave Management Platform 8.2.2.1
    I want to monitor UPS for example. How its possible?
  • 10.  RE: Can I install 3rd party MIBS into Airwave
    Posted Mar 21, 2019 04:31 AM
    Please file feature request
    https://innovate.arubanetworks.com/portal_session/new
