Can I install CPPM below required specs because I expect a low amount of users
  • 1.  Can I install CPPM below required specs because I expect a low amount of users
    Posted Feb 19, 2014 06:23 PM
    Hey all,
    Can I install the CP-VA-5K with the requirement specs of CPU/RAM/HDD based off the CP-VA-500 if I only expect the client to have 100 devices a day?
    Or instead if it matters will my CP-VA-5K licence still work if I install using the CP-VA-500 ova so that I don't use as much resources for the VM?
    Brendon
    My first post, tell me if I do something wrong.
  • 2.  RE: Can I install CPPM below required specs because I expect a low amount of users
    Posted Feb 19, 2014 06:24 PM
    NO
  • 3.  RE: Can I install CPPM below required specs because I expect a low amount of users
    Posted Feb 19, 2014 06:31 PM
    No to which question, or both?
  • 4.  RE: Can I install CPPM below required specs because I expect a low amount of users
    Posted Feb 19, 2014 06:35 PM
    No to both.
    If you install below spec then you are running an unsupported configuration and TAC will not support it.
    I would suggest that you work with your local TM/SE and Clearpass Specialist.
    Can you Send me your contact information in a private message and I will notifiy your local team to work with you.
  • 5.  RE: Can I install CPPM below required specs because I expect a low amount of users
    Posted Feb 19, 2014 07:29 PM
    For anyone who is interested - I am working with a ClearPass specalist in my area. It looks like I will downgrade my license from 5K to 500 so that I can install the CP-VA-500.
    CP-VA-500 is still more than enough for my client and this helps the VM fit with the clients resource capacity.
    Cheers all
