Can I integrate Aruba with Palo Alto without Clearpass?
  • 1.  Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 18, 2019 11:33 PM
    Hello
    Thanks.
  • 2.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 19, 2019 12:43 AM
    Yes you can. What is your setup? Controller based or IAP? What software version are you running?
  • 3.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 19, 2019 03:29 AM
    Hello JayBee
    Now, I'm implementing the Palo Alto Firewall and I need this firewall has authentication user/identity and manage security of client via palo alto.
    My aruba setup as controller based version 7010
  • 4.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 19, 2019 04:14 AM
    Check the ArubaOS documentation for the direct Palo Alto integration. Link is for 8.x, it works similar for 6.5.
  • 5.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
  • 6.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 19, 2019 04:34 AM
    Hello Willem,
    Thanks, this article the controller can integrate to Palo directly ?
    Not have clearpass ?
  • 7.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 19, 2019 04:37 AM
    Correct. Direct integration controller to Palo Alto, no ClearPass required.
  • 8.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 19, 2019 05:14 AM
    Herman,
    Many thanks for suggestion.
  • 9.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 23, 2019 12:33 AM
    Hello Herman
    Can you share installation guide to me ?
  • 10.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 23, 2019 03:54 AM
    The configuration guide was referenced for the Palo Alto integration above: https://www.arubanetworks.com/techdocs/ArubaOS_83_Web_Help/content/arubaframestyles/pan%20firewall%20integration/pan_firew_integ.htm
    For other versions than ArubaOS 8.3/8.4, the guide can be found from the support page: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/218/Default.aspx
  • 11.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 23, 2019 06:06 AM
    Dear Herman
    Thank you.
    How about fortinet ? It can integrate same palo ?
  • 12.  RE: Can I integrate Aruba with Palo Alto without Clearpass?
    Posted Apr 23, 2019 06:14 AM
    As far as I know, the issue is that Fortinet hasn't opened up their API to the level of other vendors. I haven't done that integration myself, but from 'having heard' there might be a partial integration via sending RADIUS accounting to your firewall. That doesn't include role and device information, but the IP-username mapping may work. As said, I have not tried, nor I have specific documentation on how to set that up on the firewall side. I assume that configuring RADIUS accounting on the Aruba side is trivial for you.
