Can I make different SSIDs per AP on the virtual controller.
  • 1.  Can I make different SSIDs per AP on the virtual controller.
    Posted Jul 04, 2018 11:10 PM
    Hi, I have a question.
    I would like to use IAP-207 for each floor.
    The AP's total number is 22
    I'm going to use a virtual controller
    My question is, can I make different SSIDs per AP?
    All APs are in the same vlan.
    The reason for setting
    Because the wireless LAN I used before It was a controller type and all AP used the same ssid.
    By the way
    There is a phenomenon that a user connects to another floor AP without connecting to the floor AP which the user belongs.
    So this time , I want to make that the user is forced to access the AP on his floor.
    I know it's passible if set it to standalone.
    But I want to make the management convenience by the virtual control method.
  • 2.  RE: Can I make different SSIDs per AP on the virtual controller.
    Posted Jul 04, 2018 11:56 PM
    I learned how to set it up easily by setting it directly.
    Thanks for reading.
