last person joined: 2 hours ago
Can I modify a iAP's configuration by curl command ?
  • 1.  Can I modify a iAP's configuration by curl command ?
    Posted Dec 17, 2014 01:46 AM
    Hi Folks,
    Can I modify iAP's configuration by curl command ?
    ArubaOS (MODEL: RAP-109), Version 6.4.2.0-4.1.1.0
    [CLI]
    # show aps
    [webUI]
    curl -s -k -c .cookie -d "opcode=support&cmd=%27show aps%27&refresh=false&sid=SESSION_ID" https://10.0.0.1:4343/swarm.cgi
    [CLI]
    # configuer terminal
    (config) # wlan ssid-profile TEST
    (SSID Profile "TEST") # end
    # commit apply
    [webUI]
    ??? I don't know how ???
    Any help is greatly appreciated.
    mitsu
