last person joined: 11 hours ago
Can I put an AP-125 behnd a RAP-109 when the RAP is not running any wireless.
  • 1.  Can I put an AP-125 behnd a RAP-109 when the RAP is not running any wireless.
    Posted Feb 11, 2014 05:31 PM
    The AP gets a dhcp address but  doesn't setup a tunnel or function as an AP. Do I need a different model?
  • 2.  RE: Can I put an AP-125 behnd a RAP-109 when the RAP is not running any wireless.
    Posted Feb 11, 2014 06:05 PM
    Have you set the port up to tunnel back to the controller, and with a vlan that is on the controller?
    It won't matter what model, the AP125 is fine.
  • 3.  RE: Can I put an AP-125 behnd a RAP-109 when the RAP is not running any wireless.
    Posted Feb 11, 2014 06:21 PM
    The vlan for the AP is on the controller and the AP gets a dhcp address and initially goes to the controller. Trying to configure it doesn't work. I'll repeat the setup and open a case if it fails again. Thank you. - Jim
  • 4.  RE: Can I put an AP-125 behnd a RAP-109 when the RAP is not running any wireless.
    Posted Feb 11, 2014 06:49 PM
    I tried this before and it was very inconsistent , the AP keeps rebooting over and over.
  • 5.  RE: Can I put an AP-125 behnd a RAP-109 when the RAP is not running any wireless.
    Posted Feb 11, 2014 06:51 PM
    I removed the RAP-109 and put an AP-125 with the same configuration and it worked just fine. I didn't know if the RAP-109 is up to the job or not. Thanks for the info.
  • 6.  RE: Can I put an AP-125 behnd a RAP-109 when the RAP is not running any wireless.
    Posted Feb 11, 2014 06:25 PM
    Having an AP behing an RAP is not a recommended Aruba deployment since you may experience issues because you are creating a GRE Tunnel (AP) through a RAP (GRE/IPSEC)
    You should probably try making the AP125 a RemoteAP
    Through the console you could do it:
    setenv remote_ap=1
    save
    boot
