Cloud Managed Networks
last person joined: 8 hours ago
Can I see Client's IP address for a Layer 2 switch on Central?
This thread has been viewed 16 times
  • 1.  Can I see Client's IP address for a Layer 2 switch on Central?
    Posted Feb 15, 2022 06:51 AM
    I am wondering if I can see the client's IP address under the "Client" Tab in a specific switch.
    This is a VSF of 5 6200 switches that do only layer 2.
    Best regards,
    Alon Haber
  • 2.  RE: Can I see Client's IP address for a Layer 2 switch on Central?
    Posted Feb 15, 2022 06:40 PM
    In the monitoring pages in Aruba Central, the IP address for the connected wired clients on AOS-CX switches might not be displayed if the Client IP tracker is not enabled on the switch.
    you can enable "client IP track" either from the Template based groups or using Multiedit.
    Here is the commands you need.
    https://www.arubanetworks.com/techdocs/AOS-CX/10.09/HTML/cli_6200/Content/Chp_IPClientTrack/IPClientTrack_cmds/cli-tra-ip.htm
  • 3.  RE: Can I see Client's IP address for a Layer 2 switch on Central?
    Posted Feb 23, 2022 04:23 AM
    Thank you.
    I did it, and it worked.
    Alon Haber
