I need to do a Wireless Site Survey to a Client using a IAP-215(client requirements) but I only have a IAP-225 so I would like to know if modifiying some parameters in the IAP-225 I can simulate an IAP-215? Thanks!
Are you doing an active or passive survey?
Are you measuring the 5ghz with 20/40/ or 80 mhz wide channels?
Hi cjoseph,
I'm doing a Passive survey and yes I'm measuring the 5ghz with 20/40
What type of environment is this? If it is an office environment, it should not be a problem. If it is a warehouse, or something with high ceilings, you need to use the AP225.
it's an office enviroment
You should be fine with that arrangement.
