Can I switch between 2 networks transparently?
  • 1.  Can I switch between 2 networks transparently?
    Posted Nov 04, 2014 07:38 PM
    I have configured 2 network.
    1 - Instant Red
    2 - Red Mobility Controller
    I have 3 SSID configured EXACTLY THE SAME on both networks/physical and virtual
    Can I switch between networks transparently?
  • 2.  RE: Can I switch between 2 networks transparently?
    Posted Nov 04, 2014 08:10 PM
    If everything matches (encryption, keys, RADIUS servers, etc), then you should be able to roam between them without issue although the roam may take a little bit longer than normal.
    This is not a recommended design.
  • 3.  RE: Can I switch between 2 networks transparently?
    Posted Nov 04, 2014 10:10 PM
    The configuration is follow:
    1.- Mobility Controllers 650 - 16 APS
    2.- Aruba Instant (controller) with 7 AP
    The 2 controllers (Physical and Virtual) have the same SSID, encryption, keys, RADIUS servers, captive portal,etc.
    In both have navigation.
    The problem is to change the SSID (UAO) -650 to SSID (UAO) -Instant. Is necessary to forget the network, put off the network adapter, and start the connection again.
    The change is not made between the 2 networks transparently
    Why?
  • 4.  RE: Can I switch between 2 networks transparently?
    Posted Nov 04, 2014 10:14 PM
    What authentication method are you using?
    PSK? EAP-PEAP? EAP-TLS?
  • 5.  RE: Can I switch between 2 networks transparently?
    Posted Nov 04, 2014 10:31 PM
    Ok
    SSID UAO-AL
    WPA2 and MAC Authentication
    SSID UAO-I
    LDAP authentication
    SSID UAO-AD
    SSID UAO-I   are most problems.
  • 6.  RE: Can I switch between 2 networks transparently?
    Posted Nov 04, 2014 10:35 PM
    This is likely because the two environments are using different server certificates for EAP.
    Your only option to allow this work seamlessly is to add a radius server to your environment and point both the instant cluster and controllers at it. You'll still need to manually reconnect the clients.
  • 7.  RE: Can I switch between 2 networks transparently?
    Posted Nov 04, 2014 10:48 PM
    Ok, authentication is done with the LDAP server do match with the captive portal.
    Accepts the credentials but don´t gives navigation, tomake the process mentioned above.
    And given the IAP controller IP 0.0.0.0 to the diveces
