Can I upload my own cert for the WebUI on an IAP?
  • 1.  Can I upload my own cert for the WebUI on an IAP?
    Posted May 08, 2017 08:55 AM
    I've been trying to find where to do this on the IAP if possible - I'm hoping someone here might be able to help!
    I'm trying to upload a cert for the WebUI of our IAPs (we've got a wildcard for our domain so why not) - the closes I've found is under Maintenance -> Certificates -> Upload new certificate, but the only options for the certificates here are for CA, Auth Server, Captive Portal and RadSec.
    Have I missed something?  Any advice would be much appreciated - thanks!
  • 2.  RE: Can I upload my own cert for the WebUI on an IAP?
    Posted May 08, 2017 09:04 AM
  • 3.  RE: Can I upload my own cert for the WebUI on an IAP?
    Posted May 08, 2017 08:11 PM
    Thanks Colin, that answers my question perfectly!
    I can only seem to find 6.5.1 for my device (305) from here: http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/24556/Default.aspx
    Is this available as yet?
    Chris.
