Can i use 3rd party SFP's on Aruba Mobility Conductor (MM-HW-10K)?
  • 1.  Can i use 3rd party SFP's on Aruba Mobility Conductor (MM-HW-10K)?
    Posted Jul 18, 2024 07:52 AM
    Hi AirHeads,
    One of my client is waiting for the Aruba SFP+ to arrive his site,until than he would  like to connect the  Aruba Mobility Conductor (MM-HW-10K) with 3rd party SFP's , Does the Aruba Conductor got any SFP limitations ? or unsupported command?  Anyone knows?
    (*) If i helped you , Please do kudos me as a thank you (*)
    Aruba AirHeads - Because mobility matters.
  • 2.  RE: Can i use 3rd party SFP's on Aruba Mobility Conductor (MM-HW-10K)?
    Posted Jul 18, 2024 08:00 AM
    I have used 3rd party SFPs on Aruba 7210 controller and it worked for me but not sure it will work for you. Better you should connect SFP on controller and test it.
  • 3.  RE: Can i use 3rd party SFP's on Aruba Mobility Conductor (MM-HW-10K)?
    Posted Jul 18, 2024 08:10 AM
    I'm talking about Conductor not an 72XX Controller (MD)
  • 4.  RE: Can i use 3rd party SFP's on Aruba Mobility Conductor (MM-HW-10K)?
    Posted Jul 18, 2024 08:16 AM
    it doesn't matter which device you have. I suggest you to connect and verify.
