can i use dhcp finger print to isolate devices in a specific VLAN
  • 1.  can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 26, 2013 10:27 AM
    we are trying to move all the androids and the iphones in a specific VLAN where. Is this possible using dhcp finger print?
    Adrian
  • 2.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 26, 2013 11:50 AM
    Edited; see Colin's response below:
    No, this is not possible as the fingerprinting takes place after the device is requesting a DHCP address (thus already assigned to a VLAN).
  • 3.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 26, 2013 12:12 PM
    This works as of ArubaOS 6.2 and above with open and encrypted SSIDs:
  • 4.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 26, 2013 01:27 PM
    any other opinions? If this is possible will you please add the required steps for setting it up?
    thanks
  • 5.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 26, 2013 01:31 PM
    thanks
    The screenshot is from the 6.2 release notes.  The DHCP fingerprinting app note is here:  http://www.arubanetworks.com/wp-content/uploads/AOS-DHCP-FingerPrint-AppNote.pdf?repo=tech
  • 6.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 26, 2013 01:43 PM
    1) Set up the UDR under Security > Authentication > User Rules
    2) Apply the UDR to the AAA profile
  • 7.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 26, 2013 01:59 PM
    Thank you all for the reply. Tim I have doen these steps but I ma not sure what to do next. maybe I should provide more info. We have a M3k with over 400 105 AP and 30 VLANs in a even pool. we have probably over 50% of the devices connected iphones and androids. We have issues with DHCP scopes being full and even managing the lease time  down to 30 minutes will crate a such a big difference between user, IPs in the controller VLAN and IPs in the DHCP server ( external) like 2500/3000/5500. The DHCP requests/renewal trigger DNS updates also and that is something we will try to avoid by moving all the iphones and androids in a differnet pool where we can mamage the DHCP scope t o not provide DNS pointers at all. We need the DNS for LAN Desk. Now if I will fingerprint the androids as an examle how I will manage to assign them to a different VLAN pool?
    Tim how do you manage this without clearpass?
    Adrian
  • 8.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 26, 2013 02:30 PM
    You can assign a single VLAN or a VLAN pool in the UDR.
    After you have applied the UDR to the AAA profile, the configuration is complete.
    Since you are using DHCP options instead of profiling data, ClearPass is not required for this situation.
  • 9.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 30, 2013 09:10 AM
    Thanks Tim. It still doesn't work. I can see the devices being assigned to different VLANs. Anything that needs to be done in the DHCP server?
  • 10.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 30, 2013 09:13 AM
    What type of authentication are you using on the SSID?
  • 11.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 30, 2013 09:17 AM
    802.1x with the user derivation rule crated "android"
  • 12.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 30, 2013 10:31 AM
    Adrian.Lupea,
    What version of ArubaOS are you using?
    Are clients being put into that role with the user derivation rule?
    Are clients being put into that VLAN? (show user-table verbose)
  • 13.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 30, 2013 10:46 AM
    ArubaOS ver 6.1.3.5
    I have only one role and I have added the user derivation rule to that role so all devices are in the same role.
    Some of them are some of them are not.
    adrian
  • 14.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 30, 2013 10:47 AM
    ArubaOS ver 6.1.3.5
    adrian
    Adrian,
    For this to work with 802.1x you need to be running ArubaOS 6.2 and above (please see release notes screenshot in a previous post).  It will NOT work with 6.1.x
  • 15.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Sep 30, 2013 10:49 AM
    Thanks. I have missed that. I will upgrade.
    Adrian
  • 16.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Oct 01, 2013 09:12 AM
    It's working so far. Hope that this will be the solution. Thanks eveyone.
    adrian
  • 17.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Oct 03, 2013 08:30 AM
    Although I have a certain number of devices in the assigned VLAN the controller doesn't capture a large number of them. Here are my questions:
    1. Is there more DHCP fingerprinting that I can use beside 3C64686370636420342E302E3135?
    2. I can see a lot of devices are not authenticated but that will not stop them form receiving an IP. Is there a way to not allow an IP until logged in?
    3. Anybody noticed a discrepancy on the users numbers between dashboard and monitoring screens? there are more users in the monitoring>clients and all of them have IPs and there are less users in the dashboard and a lot of users are not displaying any IPs.
    thanks,
    Adrian
  • 18.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Jan 08, 2014 05:19 AM
    we are facing issues with device finger printing
    controller: 6000
    OS:6.3.0.2
    ssid : 802.1x with windows 8 nps
    dhcp: windows 8 dhcp server
    Issue: There are  three ap groups for three buildings, when user moves from one group to another the user rule which is set to assign vlan based on the device type doen't work . for eg
    ap group 1 . all ipads -vlan 1 ssid: staff
    ap group 2 .all ipads -vlan 2  ssid: staff
    device type:ipad
    when the user is in ap group 1 the user rule assign ip from vlan 1 but when the user moves to ap group 2 the ipaddress is still from vlan1 ,  however if we connect to another ssid and get a different ip  (say guest) and try to reconnect back to the staff ssid then the device will get ipadress from vlan2 . Any help
  • 19.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Jan 08, 2014 05:46 AM
    controller: 6000
    OS:6.3.0.2
    device type:ipad
    If you have a client that is roaming from one access point to another on the same SSID, the client will assume that it is on the same VLAN and not attempt to obtain a new ip address.  If you change the VLAN in the background the client will think it is on the same VLAN and NOT obtain a different DHCP address.  If you change SSIDs, however the client will always attempt to get another DHCP address because it assumes it will be on a new VLAN.  Do not design your network where the network is changed in the background when your client roams to another access point on the same SSID.  It will not work in the majority of cases and is not a good strategy.
  • 20.  RE: can i use dhcp finger print to isolate devices in a specific VLAN
    Posted Jan 14, 2014 02:51 AM
    we are forced to do this because of the apple tv /ipad airplay issues
    we have more 128 apple tv's distributed across the campus . ipad have  limitation of displaying only 64 apple tv's in airplay
    so what we did is as below
    divided the campus in to three ap groups based on building
    ssid -staff-building 1-ap group 1 - aaa servers -group 1 - apple tv's in vlan1 (wired) - staff will get vlan 1     (no: of apple tv's 40)
    ssid-staff -building 2 -ap group 2 - aaa servers -group 2 - apple tv's in vlan 2 (wired) - staff will get vlan 2   (no: of apple tv's 40)
    ssid-staff -building 3 -ap group 3 - aaa servers -group 3 - apple tv's in vlan 3 (wired) - staff will get vlan 3   (no: of apple tv's 48)
    This is working perefectly fine with out enabling airplay on aruba and client romaing is also fine . when staff goes from ap group 1 to ap group- 2 device gets the correct vlan and dhcp . This is working fine with windows/ios/android. Now what we are trying is using device finger printing trying to isolate ipad's by putting the user specific rules . when we enable user specifi rule and the user roams from one ap group to other the vlan doesn't changes automatically ,however if we disconnect and connect to guest network and get a different lease and reconnect back to staff ssid then the vlan /dhcp comes correctly . any advise
    Binu
