Can IAP send UCC data to Airwave?
  • 1.  Can IAP send UCC data to Airwave?
    Posted Jan 09, 2017 09:55 AM
    Hi.
    Is it possible for IAP to send UCC data to Airwave or does it require a mobility controller?
    Using IAP 6.5.0
    Airwave  8.2.2.1
    Best regards,
    Petter Miller
  • 2.  RE: Can IAP send UCC data to Airwave?
    Posted Jan 09, 2017 10:54 AM
    It requires AMON to see that data in AirWave , AMON is not supported yet on the IAPs but it is expected supported at some point .
    AMON it is currently supported on the Aruba Controllers
    Get Outlook for iOS
  • 3.  RE: Can IAP send UCC data to Airwave?
    Get Outlook for iOS
