Can IAP105's be in the same cluster as IAP104's
  • 1.  Can IAP105's be in the same cluster as IAP104's
    Posted Feb 27, 2013 07:54 AM
    Can they work together as they have internal and external antennas.
    regards
    Justin
  • 2.  RE: Can IAP105's be in the same cluster as IAP104's
    Posted Feb 27, 2013 08:12 AM
    Yes, you can mix IAP versions in the same cluster.
  • 3.  RE: Can IAP105's be in the same cluster as IAP104's
    Posted Feb 27, 2013 09:43 AM
    Thank you
