can IAP315 and IAP-225 cluster or mesh
  • 1.  can IAP315 and IAP-225 cluster or mesh
    Posted 21 days ago
    Hello
    I bought a pair of IAP-315 off eBay (from the Aruba refurb store) a few years back. around that time we did an Aruba refresh at couple locations at work. (form IAP225 to IAP315)
    My boss signed off on about 12 of those device to go to us :), I got two of them.
    however I am just getting into looking at them at home a year + later.
    plugged it in an the IAP-215 upgraded to 8.6.0.18
    my IAP-315 are the 8.9.0.2 (it auto upgraded to this)
    is it not possible for them to Cluster?
    Is it possible for them to MESH ? I would really like the 225 to cover some low signal area in my house without running new cables.
    I assume the version mismatch is the issue
    Jul 24 14:29:13   mini_httpd[7205]: handle_request, 3411: Try to check post auth user 192.168.1.103, dst 172.31.98.1
    Jul 24 14:29:13   syslog: main, 3437: opcode is show
    Jul 24 14:29:13   mini_httpd[7208]: handle_request: 3150: SSL_accept fail, child exit after 0 requests error:00000001:lib(0):func(0):reason(1)
    Jul 24 14:29:13   mini_httpd[7209]: handle_request, 3392: 192.168.1.103, 61928, size 592
    Jul 24 14:29:13   mini_httpd[7209]: handle_request, 3411: Try to check post auth user 192.168.1.103, dst 172.31.98.1
    Jul 24 14:29:14   cli[6098]: <341097> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli|  recv_image_check: mac-84:d4:7e:xxxx, version-8.6.0.18-8.6.0.18_84257, ccode_idx-0.
    Jul 24 14:29:14   cli[6098]: save_sn2file: this member have been involved, pass
    Jul 24 14:29:14   cli[6098]: <341004> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli|  ccode_index_to_ccode_array_idx_vc, return i = 0
    Jul 24 14:29:14   cli[6098]: <341004> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli|  is_reg_domain_match my_arr_idx = 0, other_arr_idx= 0
    Jul 24 14:29:14   cli[6098]: <341052> <ERRS> |AP OFFICE:db:f8@192.168.101.101 cli|  recv_image_check, 2977: AP class not match, Conductor-40, Member-25.
    Jul 24 14:29:14   cli[6098]: find_class_seed_ap:class is 40
    Jul 24 14:29:14   cli[6098]: do not find the same class from ap list 25
    Jul 24 14:29:14   cli[6098]: <341004> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli|  Image_sync_via_isc
    Jul 24 14:29:14   cli[6098]: initiate_image_mismatch:could not find the url from cache, send the url request to activate.
    Jul 24 14:29:14   cli[6098]: <341004> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli|  isc_image_url_request: Centaurus,8.9.0.2-8.9.0.2_83074
    Jul 24 14:29:14   awc[6095]: [activate] receive isc request
    Jul 24 14:29:14   awc[6095]: [activate] tcp_connect: begin resolve 'device.arubanetworks.com'
    Jul 24 14:29:14   awc[6095]: [activate] tcp_connect: 251: recv timeout set to 5
    Jul 24 14:29:14   awc[6095]: [activate] tcp_connect: 258: send timeout set to 5
    Jul 24 14:29:14   awc[6095]: [activate] awc_init_connection: 2970: connected to device.arubanetworks.com:443
    Jul 24 14:29:14   awc[6095]: [activate] awc_init_connection: 3033: cert verify: enable, domainame verify: enable
    Jul 24 14:29:14   awc[6095]: [activate] awc_init_connection: 3062: Loading local CA certificates
    Jul 24 14:29:14   awc[6095]: [activate] verify_callback: 2821: preverify_ok:1, chain count:4.
    if that is the case can this ever work? do they have repeater mode?
  • 2.  RE: can IAP315 and IAP-225 cluster or mesh
    Posted 21 days ago
    you need the APs to be on the same firmware to join the instant cluster.
  • 3.  RE: can IAP315 and IAP-225 cluster or mesh
    Posted 21 days ago
    You can downgrade both the 225 and 315's to the 8.6.0.2 factory image, then form a cluster of all of them, and from there use the 'in product upgrade' to get to the latest 8.6 version.
    For the downgrade, make sure that you have a cluster of only 225s or only 315s (power off the other APs), then when all are on the same version you can join them together. If you have access to the Aruba Support Portal with an active support contract, you can go to the latest 8.6 release immediately.
