Can IAPs work on routed switch interfaces?
  • 1.  Can IAPs work on routed switch interfaces?
    Posted Mar 19, 2013 10:46 AM
    I have 2-IAP 134's that I'm going to be using for a mesh bridge. In my lab setup I got the mesh to work great on switchports configured as trunks. I can pass vlan traffic across the bridge with no problems.
    What I would like to do is to configure my switchports as a routed interface with a /29 address and give the IAPs a static IP address in the same /29 range. The vlan SVI's will live on the portal switch.
    Long question short. Can IAPs work properly on a routed interface? Or should the switchports be configured as trunk ports?
  • 2.  RE: Can IAPs work on routed switch interfaces?
    Posted Mar 19, 2013 01:53 PM
    The iAPs will need to see each other in layer-2 for the virtual controller to work - only a problem if you need more than one iAP in a location.
    That aside, the vlan for clients can be gre-tunneled back to the portal switch, so I don't see a problem there.
