Can meridian software work with Instant Access points
  • 1.  Can meridian software work with Instant Access points
    Posted Aug 27, 2014 03:40 AM
    Hi All
    Need to know for Merdian Apps to work , does the solution have to be controller based or can you use instant APs?
    Also which of the Instant aps support location tracking? or can i sue any one of them
    Thank you  in advance
    Sven
    #Meridian
    #LocationServices
    #ALE
  • 2.  RE: Can meridian software work with Instant Access points
    Posted Aug 27, 2014 10:34 AM
    Yes - starting with 4.0, IAPs support integration with Aruba's ALE which Meridian uses for data mining.
