Can multiple class IAPs form the cluster without difference of configuration ?
  • 1.  Can multiple class IAPs form the cluster without difference of configuration ?
    Posted May 07, 2015 11:04 PM
    Hi Airheads.
    I have a question about iap cluster.
    According to this article, we can form instant cluster with different classes (ex. Aries & Taurus).
    It means there is no difference of configuration between each class ?
    So we can switch a master to the different class iap or restore a configuration file from the different class iap without any problem...
    Is this correct ???
  • 2.  RE: Can multiple class IAPs form the cluster without difference of configuration ?
    Posted May 07, 2015 11:06 PM
    As long as they are running the same code version.
  • 3.  RE: Can multiple class IAPs form the cluster without difference of configuration ?
    Posted May 07, 2015 11:36 PM
    Hi Tim,
    Thank you for so quick response !
    Let me make sure..
    In a following example, It means that all of "6.4.2.3-4.1.2.1_49445" must be match ?
    ArubaInstant_Centaurus_6.4.2.3-4.1.2.1_49445
    ArubaInstant_Taurus_6.4.2.3-4.1.2.1_49445
    Atsushi Ikeda
  • 4.  RE: Can multiple class IAPs form the cluster without difference of configuration ?
    Posted May 07, 2015 11:40 PM
    Yes. The model on the image name can differ (Pegasus, etc), but the version number needs to match.
    Tim
