Can no longer access/ping the Controller
  • 1.  Can no longer access/ping the Controller
    Posted Mar 10, 2020 11:11 AM
    I can no longer access the controller via its web interface.  I can still connect to the APs via their web GUI.  I also cannot ping the controller.  The problem started after I rebooted the "master AP."  After the "master AP" rebooted, I can no longer ping the controller IP or access the controller via its web interface.  I have rebooted all the APs since rebooting the master.  No change.  Any thoughts on how I can fix this?  Thanks.
  • 2.  RE: Can no longer access/ping the Controller
    Posted Mar 10, 2020 12:43 PM
    You mentioned that you can connect to Web GUI of APs
    " I can still connect to the APs via their web GUI"
    When you try to connect to web gui of any IAP in a cluster, you are redirected to VC of the cluster automatically. What is happening in your case? simply rebooting the master shouldnt be a problem. Did you change any other settings like configuring preferred master on multiple APs?
  • 3.  RE: Can no longer access/ping the Controller
    Posted Mar 10, 2020 01:29 PM
    Controller IP: 10.102.220.200.  APs: 10.102.220.20-24.
    If I try to go to 10.102.220.200, I receive a timeout browser message.
    If I go to 10.102.220.20, for example, I am redirected to the IP of the AP that is listed as "Master."
    So if AP 10.102.220.23 is "Master," when I go to 10.102.220.20, 21, 22 or 24, I am redirected to 10.102.220.23.  If I reboot 23 and 21 becomes "Master," then I am always redirected to 21 any time I try to access one of the APs directly through the web GUI.
  • 4.  RE: Can no longer access/ping the Controller
    Posted Mar 10, 2020 01:41 PM
    Are you connecting to controller ip via same subnet or different subnet? have you tried to configure other network settings for VC as well?
  • 5.  RE: Can no longer access/ping the Controller
    Posted Mar 10, 2020 01:44 PM
    We have a separate "AP VLAN."  We can access the "AP VLAN" from our "Main VLAN."  I am accessing the APs through our "Main VLAN."  If I setup a switch port for just the "AP VLAN," I am still unable to connect to the controller IP.  The virtual controller had been working fine.  It is not working now after a reboot of one of the "main AP."
  • 6.  RE: Can no longer access/ping the Controller
    Posted Mar 10, 2020 02:02 PM
    Can you share the model of APs and firmware version
  • 7.  RE: Can no longer access/ping the Controller
    Posted Mar 10, 2020 02:05 PM
    Model: 315
    Software version: 8.3.0.9.
  • 8.  RE: Can no longer access/ping the Controller
    Posted Mar 10, 2020 02:32 PM
    Ok i will lab it up tomorrow to see if i can reproduce it
  • 9.  RE: Can no longer access/ping the Controller
    Posted Mar 10, 2020 02:43 PM
    Thanks.  I have even tried changing the VC IP to see if this would 'fix' the issue.  Even after changing the VC IP, I am still unable to access the VC directly through the IP.  Are there any logs that we can review?
  • 10.  RE: Can no longer access/ping the Controller
    Posted Mar 17, 2020 09:08 AM
    I resolved this issue by removing the gateway on the Virtual Controller.  Once I removed the gateway, I was able to access the virtual controller IP.  Again, I didn't change the configuration/network/etc.  I only rebooted the "Master AP."  Is this a known issue?
  • 11.  RE: Can no longer access/ping the Controller
    Posted Mar 17, 2020 09:55 AM
    Removing what gateway?
  • 12.  RE: Can no longer access/ping the Controller
    Posted Mar 17, 2020 09:58 AM
    The gateway on the Virtual Controller.
    System -> General
    I removed the Gateway and changed the "Virtual Controller network settings" to "Default."
  • 13.  RE: Can no longer access/ping the Controller
    Posted Mar 17, 2020 10:02 AM
    Why do you enter the gateway?  You should let the controller obtain its ip address via dhcp...
  • 14.  RE: Can no longer access/ping the Controller
    Posted Mar 17, 2020 10:03 AM
    We set a static IP on all of our APs and Virtual Controller.  We had the gateway setup on our virtual controller.  We do not use DHCP for APs/Virtual Controller.
  • 15.  RE: Can no longer access/ping the Controller
    Posted Mar 17, 2020 10:15 AM
    Instant is designed to use dhcp for all the pieces.  Setting static ip addresses for all your instant APs opens you up for more administrative work.  You can always configure a virtual controller ip address, that the Virtual Controller will always have, so that you can login to a consistent ip address, while still using dhcp for your instant APs to avoid the management overhead.
    I don't know why you are having problems while configuring a default gateway, but that is not a standard setup, so I cannot answer that..
  • 16.  RE: Can no longer access/ping the Controller
    Posted Mar 17, 2020 10:21 AM
    We always use static IPs.  Much less overhead for us to use static IPs.
    In terms of my original problem, it seems like there is an issue when a gateway is statically set.  Things will work for a while, then suddenly, just stop working.  That is, with a static gateway, one can access the virtual controller.  Then, suddenly, one cannot access the virtual controller.  Removing the static gateway 'fixes' this problem.
  • 17.  RE: Can no longer access/ping the Controller
    Posted Mar 17, 2020 10:27 AM
    Thank you.  This can be a cautionary tale to others.
