can not boot my access point
  • 1.  can not boot my access point
    Posted Oct 22, 2017 12:19 PM
    Good Evening
    I have a problem with my ap:APIN0205
    S/N:CNCDHMJ5GG
    After I reset this AP
    using this command :Write Erase All
    I can not boot to it
    it always stops int this stage and restarts after it
    Getting an IP address...
    Dec 31 16:00:17 udhcpc[1363]: udhcpc (v0.9.9-pre) started
    Dec 31 16:00:17 udhcpc[1363]: send_discover: pkt num 0, secs 0
    Dec 31 16:00:17 udhcpc[1363]: Sending discover...
    Dec 31 16:00:19 udhcpc[1363]: send_discover: pkt num 1, secs 512
    Dec 31 16:00:19 udhcpc[1363]: Sending discover...
    Dec 31 16:00:21 udhcpc[1363]: send_discover: pkt num 2, secs 1024
    Dec 31 16:00:21 udhcpc[1363]: Sending discover...
    Dec 31 16:00:23 udhcpc[1363]: No lease, forking to background.
    Dec 31 16:01:39 udhcpc[1468]: Sending discover...
    [ 105.458000] Picked up default IP a9fe9c77, rand 9c77
    [ 110.468000] Default IP is ready
    Installing default ip.
    Default IP comes up.
    [ 143.534000] ip_time_handler: Got ip and packets on bond0 Started master election 244-0, rand 18
    [ 143.580000] Adding bridge entry for magic vlan GW, ifindex 8450, a8:bd:27:c8:c1:74
    [ 143.582000] (00:02:25) !!! Init ---> Slave
    DHCP timed out.
    DHCP got ip address.
    169.254.156.119 255.255.0.0
    Compressing all files in the /etc/httpd directory...
    [ 144.154000] (00:02:26) Rebooting AP due to default-ip is denied in this network (a8:bd:27:c8:e5:dc 192.168.3.189)
    [ 144.154000]
    [ 144.566000] notify cli0 to reboot system
    [ 144.970000] (00:02:27) Rebooting AP due to default-ip is denied in this network (a8:bd:27:c8:e5:dc 192.168.3.189)
    [ 144.970000]
    Dec 31 16:02:27 udhcpc[1468]: send_discover: pkt num 0, secs 33280
    Dec 31 16:02:27 udhcpc[1468]: Sending discover...
    [ 145.830000] (00:02:28) Rebooting AP due to default-ip is denied in this network (a8:bd:27:c8:e5:dc 192.168.3.189)
    [ 145.830000]
    [ 146.692000] (00:02:29) Rebooting AP due to default-ip is denied in this network (a8:bd:27:c8:e5:dc 192.168.3.189)
    [ 146.692000]
    Dec 31 16:02:29 udhcpc[1468]: send_discover: pkt num 1, secs 33792
    Dec 31 16:02:29 udhcpc[1468]: Sending discover...
    [ 147.552000] (00:02:30) Rebooting AP due to default-ip is denied in this network (a8:bd:27:c8:e5:dc 192.168.3.189)
    [ 147.552000]
    [ 148.414000] (00:02:31) Rebooting AP due to default-ip is denied in this network (a8:bd:27:c8:e5:dc 192.168.3.189)
    [ 148.414000]
    [ 148.416000] (00:02:31) Rebooting AP due to default-ip is denied in this network (a8:bd:27:c8:e5:dc 192.168.3.189)
    [ 148.416000]
    what shall i do to solve this problem?
  • 2.  RE: can not boot my access point
    Posted Oct 22, 2017 06:40 PM
    Looks like the AP is not able to get an ip .
    Do you have dhcp enabled for the vlan assigned to the AP
    Get Outlook for iOS
  • 3.  RE: can not boot my access point
    Posted Oct 22, 2017 09:39 PM
    It looks like the default IP is being occupied by another device.
    You may need to check the DHCP service as mentioned, or statically use set another available IP address on the AP.
