Can not ping controller IP
  • 1.  Can not ping controller IP
    Posted Feb 25, 2020 02:53 AM
    Dear all friends and experts.,
    I have a topology as below :
    [Controller 01----Trunking----[Core Switches]
    - Interface VLAN  X is up on the controller
    - A laptop has IP in Vlan X, and the laptop can not ping controller
    Can you take time to help me ?, how I can ping the controller?, . Thank you so much !
  • 2.  RE: Can not ping controller IP
    MVP EXPERT
    Posted Feb 25, 2020 07:47 AM
    What is your interface configuration on the controller and switch? Do these match? Do you see an ARP entry for either end? What is the default gateway for the client and controller?
