last person joined: 8 hours ago
Can our guest network use a different gateway and wan ip then the prod network?
  • 1.  Can our guest network use a different gateway and wan ip then the prod network?
    Posted Nov 05, 2015 11:44 AM
    We are using an access point as our virtual controller. In our facility, the production network users on wireless a limited by office policy. So most people bring in their own device, and get on the "Guest Network". We have one wan ip for our network and we host our own email. We are concerned about an infected pc on our "Guest" wireless network and the possibility of it causing us to be blacklisted. Can the production network and "Guest" network be configured to use two different wan ip's to help prevent this from happening? Or other suggestions that maybe helpful?
  • 2.  RE: Can our guest network use a different gateway and wan ip then the prod network?
    Posted Nov 05, 2015 11:46 AM
    You can create nat pool with that address and then point all your guest traffic to be source natted using that pool pointed to your wan ip
  • 3.  RE: Can our guest network use a different gateway and wan ip then the prod network?
    Posted Nov 05, 2015 11:51 AM
    Appreciate your input.... can you direct me to a link or documentation on this process??
  • 4.  RE: Can our guest network use a different gateway and wan ip then the prod network?
