can use one certificate in several virtual controller of the same corporation?
  • 1.  can use one certificate in several virtual controller of the same corporation?
    Posted Nov 15, 2016 10:32 AM
    In the same corporation, there are several delegations. In eaqch delegation there are a cluster iap. Can use the same public certificate, in all cluster?
  • 2.  RE: can use one certificate in several virtual controller of the same corporation?
    Posted Nov 15, 2016 10:38 AM
    Are you referring to the captive portal certificate? If so, yes, as long as
    you have the key pair.
  • 3.  RE: can use one certificate in several virtual controller of the same corporation?
    Posted Nov 15, 2016 11:04 AM
    I need generate a csr with openssl to generate a public certificate. What common name fill to can use in several instan controller?
    [cid:image001.jpg@01D23F62.2829F930]
    Luis Miguel Lafuente Herranz
    Área Técnica
    Tel. 902270002 Fax. 902270005
    12 Centros Operativos en España, México y República Dominicana
    luismiguel.lafuente@bcsistemas.com http://www.bcsistemas.com
  • 4.  RE: can use one certificate in several virtual controller of the same corporation?
  • 5.  RE: can use one certificate in several virtual controller of the same corporation?
    Posted Nov 15, 2016 11:21 AM
    Sorry, this is clear, but when I generate a csr in openssl, What name is valid for filling common name and that the generated public certificate can be used on all virtual controllers? Any common name?
    [cid:image003.jpg@01D23F64.92DD45A0]
    Área Técnica
  • 6.  RE: can use one certificate in several virtual controller of the same corporation?
    Posted Nov 15, 2016 11:24 AM
    You can use anything you want. I always recommend it be clear to a user.
    Something like network-login.<YOUR-PUBLIC-DOMAIN></YOUR-PUBLIC-DOMAIN>
