i think 2530s with 10GE interfaces are end of sale, the current switch you can buy is CX-6100
You can enable "unsupported transceiver" that allows 3rd party transceivers to operate but obviously they are not supported.
Original Message:
Sent: Jun 08, 2022 09:11 PM
Subject: can use SFP 10Gbps Cisco for Aruba 2530 switch ?
The Cisco SFP almost certainly won't work in the Aruba switch. Third party SFP's are available which will work and are significantly cheaper than an Aruba SFP. This is one that I've used extensively but there are many others as well. https://www.fs.com/products/92099.html
Original Message:
Sent: Jun 08, 2022 08:56 PM
Hi all,
My resort used Cisco SG550 for the access switch. Is now, Cisco access switch is broken.
I want order Aruba 2530 to replace the Cisco switch. But I don't know can use the sfp+ cisco switch for Aruba 2530 switch.
Below are details Sfp+ Cisco
