Wired Intelligent Edge
can use SFP 10Gbps Cisco for Aruba 2530 switch ?
This thread has been viewed 21 times
  • 1.  can use SFP 10Gbps Cisco for Aruba 2530 switch ?
    Posted Jun 08, 2022 08:57 PM
    Hi all,
    My resort used Cisco SG550 for the access switch. Is now, Cisco access switch is broken.
    I want order Aruba 2530 to replace the Cisco switch. But I don't know can use the sfp+ cisco switch for Aruba 2530 switch.
    Below are details Sfp+ Cisco
  • 2.  RE: can use SFP 10Gbps Cisco for Aruba 2530 switch ?
    Posted Jun 08, 2022 09:12 PM
    The Cisco SFP almost certainly won't work in the Aruba switch.  Third party SFP's are available which will work and are significantly cheaper than an Aruba SFP.  This is one that I've used extensively but there are many others as well.  https://www.fs.com/products/92099.html
  • 3.  RE: can use SFP 10Gbps Cisco for Aruba 2530 switch ?
    Posted Jun 08, 2022 09:26 PM
    i think 2530s with 10GE interfaces are end of sale, the current switch you can buy is CX-6100
    You can enable "unsupported transceiver" that allows 3rd party transceivers to operate but obviously they are not supported.
  • 4.  RE: can use SFP 10Gbps Cisco for Aruba 2530 switch ?
    Posted Jun 11, 2022 09:08 PM
    Thanks, Aruba 2530 is in stock and my boss doesn't want to buy a new switch. And I need wait more than 6 months then can get new switch
  • 5.  RE: can use SFP 10Gbps Cisco for Aruba 2530 switch ?
    Posted Jun 11, 2022 09:11 PM
    Thanks, I have already contacted third-party SFP products. I hope to be compatible
    In cisco nexus, I had set the speed to 1000Mbps
  • 6.  RE: can use SFP 10Gbps Cisco for Aruba 2530 switch ?
    Posted Jun 09, 2022 01:29 AM
    As far as I know the AOS-S 2530 switches do not have SFP+ ports, the AOS-S 2540 has.
    Gerber van Beek
  • 7.  RE: can use SFP 10Gbps Cisco for Aruba 2530 switch ?
    Posted Jun 09, 2022 02:12 AM
    there used to be 253024G 2SFP+ (J9856A) and its poe version but they are all end of sale
