last person joined: 5 hours ago
Can we move Aruba 305 from VC to Master Controller.
  • 1.  Can we move Aruba 305 from VC to Master Controller.
    Posted Jan 14, 2020 12:59 PM
    We have some Aruba 305 which are connected to Virtual Controller in the same subnet but we are noticing some issue with SSIDs and was wondering if we can move Aruba 305 which is currently connected to VC and connect it on Master Controller.
  • 2.  RE: Can we move Aruba 305 from VC to Master Controller.
  • 3.  RE: Can we move Aruba 305 from VC to Master Controller.
    MVP EXPERT
    Posted Jan 14, 2020 01:11 PM
    Hi Arubanewbee,
    What kind of setup do you running, instant or controller based VMC. What OS version and what do you mean with a Master Controller? An ArubaOS8 Mobilty Master?
    We need some more details to help you.
    For urgent matters please open a TAC case.
  • 4.  RE: Can we move Aruba 305 from VC to Master Controller.
    MVP EXPERT
    If you want to convert the IAP into Campus AP (e.g Managed via a Mobility Controller) then do the following:
    https://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/IAP_management/ConvertingIAPtoCAP.htm
