In short, Yes. However there are multiple questions.
Firstly you'll need to work with Aruba TAC to migrate/move over your licenses between the current on-prem and a new AWS VM. Start by requesting a private AMI image from here to get you started in terms of an AWS deployment.... https://forms.office.com/Pages/ResponsePage.aspx?id=YSBbEGm2MUuSrCTTBNGV3IQuClHxB29IlfFFMHxWbN1UNzdVN1VXVFIxM0dJRzlGU1hWN1RKMDBVRSQlQCN0PWcu
Read this DOC for great guidance on deploying in AWS https://www.arubanetworks.com/techdocs/ClearPass/TechNotes/ClearPass_Policy_Manager_AWS/index.htm
Now, there are multiple question that I'm not going to attempt {work your your aruba partner or aruba SE} but consider;
Only one interface in AWS CPPM
No VIP supported
DO NOT PLAN on using an on-prem AD for for authN/authZ if your moving CPPM to AWS
Consider RTT
Consider how you'll get traffic to the VM..... via VPN, using an EIP etc.
This will get you started.
Danny Jump
"Passionate about CPPM"
Original Message:
Sent: Dec 19, 2020 05:54 AM
Subject: Can we move ClearPass 6.7 C2000V to Azure/AWS?
Hello All,
If Yes what would be the procedure.
Do i need to purchase any subscription or i can use current license in Azure/AWS.
MPY
