Can we terminate Aruba GRE tunnel from IAP onto ArubaOS-Switch?
  • 1.  Can we terminate Aruba GRE tunnel from IAP onto ArubaOS-Switch?
    Posted Mar 20, 2019 04:48 PM
    Can we terminate Aruba GRE tunnel from IAP onto ArubaOS-Switch (instead of terminating it on MC)?
    If yes, what is the config required?
  • 2.  RE: Can we terminate Aruba GRE tunnel from IAP onto ArubaOS-Switch?
    MVP EXPERT
    Posted Mar 20, 2019 05:26 PM
    AFAIK not, the Mobility Controller is the GRE "concentrator".
    But you can create a GRE tunnels from 2930 to the MC (they called it Tunneled-Node).
    Whay is your purpose?
  • 3.  RE: Can we terminate Aruba GRE tunnel from IAP onto ArubaOS-Switch?
    Posted Mar 20, 2019 07:30 PM
    I often set up Instant networks at several branch offices with Guest access via L2-centralised MC, and using Aruba GRE as the mechanism.
    Usually I install 1 or 2 small controllers in the data centre just to be the VPN concentrator.
    Since a switch is more useful (and often already exists in the central data centre) it would be useful if I can terminate the GRE directly on a switch and remove the small controller from the network completely.
