Can we use internal captive portal juts with AP-Capacity Licenses?
  • 1.  Can we use internal captive portal juts with AP-Capacity Licenses?
    Posted Jun 12, 2017 09:19 AM
    Hello friends,
    I have a controller working with a number of APs with just AP capacity licenses. Can I configure and use a basic internal captive portal for my users?
  • 2.  RE: Can we use internal captive portal juts with AP-Capacity Licenses?
    Posted Jun 12, 2017 09:26 AM
    yes
  • 3.  RE: Can we use internal captive portal juts with AP-Capacity Licenses?
    Posted Jun 12, 2017 10:00 AM
    TL:DR No. You will need the PEF-NG license. 1 per AP.
    If there is no PEF license users all get the same role once associated, therefore you cannot have a logon role to enforce captive portal AND an authenticated role once the guest user has logged in.
  • 4.  RE: Can we use internal captive portal juts with AP-Capacity Licenses?
    Posted Jun 12, 2017 10:03 AM
    PEF is not required for basic guest. You just cannot modify roles.
