last person joined: 10 hours ago
Can you have nested device groups
This thread has been viewed 19 times
  • 1.  Can you have nested device groups
    MVP EXPERT
    Posted Jul 26, 2021 12:47 PM
    Got a large estate comprising multiple sites, each site has multiple switches.
    like to group site switches in their own group
    Then have services that are selected based upon colledtion nad-ip-address belongs to <group name>
    ... but you cant select multiple groups at this point.
    Would be nice if we had nested groups so
    top level group = "wholeorganisation"
    which had as members  groups
    site1,site2 .....
     The servie selected by  connection nad-ip-address belongs to-group wholeorganisation
    or is there another way to do same thing?
    A​
    Alex Sharaz
  • 2.  RE: Can you have nested device groups
    Posted Jul 26, 2021 06:11 PM
    You'd have to use custom NAD attributes in a tag-like manner.
    Tim C
  • 3.  RE: Can you have nested device groups
    Posted Jul 27, 2021 03:28 AM
    You can define Device attribute in Device settings.
    And then use this attribute in your Service definition, Role Mappings or Enforcement policies.
     Best, Gorazd
    Gorazd Kikelj
  • 4.  RE: Can you have nested device groups
    MVP EXPERT
    Posted Jul 28, 2021 03:54 AM
    Thanks for this, o.k. makws sense but if you can have up to 60 locations plus that you want to have a service applied to starts gettingf messy .
    Plan here is to roll out NAC over a  multi site  estate so theory is
    Create 2 identical services except 1 runs in monitor mode
    Have the monitor mode service selecred by a device group called MONITOR
    Assign switches at a site to monitor group to check stuff is working as it should
    After tested, move switch to an "active"  device group ( or use the location example youve described) , removing it from the monitor group so the active service picks it up
    This is a phased rollout so switches will move from the monitor service to the active service
    we're talking 1000's switches over 60+sites
    So would be selecting  a service bqsed upon an OR of your location attribute  .... sort of seems messsy
    A
    Alex Sharaz
