can you help me on how to enable/move a rap from 2.4ghz to 5ghz in aurba controller GUI
  • 1.  can you help me on how to enable/move a rap from 2.4ghz to 5ghz in aurba controller GUI
    Posted May 15, 2015 03:22 AM
    can you help on how to enable/move a rap from 2.4ghz to 5ghz in aurba controller GUI,if possible with screenshots.Thanks in advance,.
  • 2.  RE: can you help me on how to enable/move a rap from 2.4ghz to 5ghz in aurba controller GUI
    Posted May 15, 2015 04:53 AM
    Hi Karthik,
    Which RAP model you are using ?
  • 3.  RE: can you help me on how to enable/move a rap from 2.4ghz to 5ghz in aurba controller GUI
    Posted May 15, 2015 05:08 AM
    The method is same for any AP. To insist you RAP to use only a-band we need to disable g-radio(in case if the RAP is dual band) as shown in the snapshot and select RF band as "a" in the AP system profile.
    for your ref :
    Please feel free for any further help needed.
