Can you mix Instant AP105 and Instant AP 204 Access Points in the same cluster?
  • 1.  Can you mix Instant AP105 and Instant AP 204 Access Points in the same cluster?
    Posted Oct 17, 2014 06:57 AM
    I would like to install Instant 105 access points but also I have a requirement for some external coverage and was thinking of installing Instant AP204 with external antennas.  I was told that AP 204's use diplexing so you can use one ANT17 for both 2.5 and 5ghz (rather than have two antennas on a IAP104).
    I would be really grateful for any advice.
  • 2.  RE: Can you mix Instant AP105 and Instant AP 204 Access Points in the same cluster?
    Posted Oct 17, 2014 08:08 AM
    Yes - this is allowed
  • 3.  RE: Can you mix Instant AP105 and Instant AP 204 Access Points in the same cluster?
    Posted Oct 17, 2014 08:13 AM
    Many thanks Seth
  • 4.  RE: Can you mix Instant AP105 and Instant AP 204 Access Points in the same cluster?
    Posted Oct 17, 2014 09:04 AM
    Make sure that they are on same version of OS before you join them
  • 5.  RE: Can you mix Instant AP105 and Instant AP 204 Access Points in the same cluster?
    Posted Oct 17, 2014 09:32 AM
    Thanks Victor
