can you put a 7005 in a port-channel%3F
  • 1.  can you put a 7005 in a port-channel%3F
    Posted Nov 07, 2016 05:05 PM
    Does the Aruba 7005 support port-channel for uplinks?  Running code 6.4.2.12  The reason I ask, everytime I try to connect a port-channeled interface to a cisco 3850, the 3850 thinks the mask is incorrect on the native vlan, even though the mask is correct on both sides for this vlan, see below:
    Aruba Config:
    interface port-channel 1
    trusted
    trusted vlan 1-4094
    switchport mode trunk
    switchport trunk native vlan 603
    switchport trunk allowed vlan 101,603,2500-2506
    interface vlan 603
    ip address 10.67.250.65 255.255.255.248
    operstate up
    Cisco Router svi config:
    interface GigabitEthernet0/1.603
    description *** MGMT Vlan ***
    encapsulation dot1Q 603 native
    ip address 10.67.250.69 255.255.255.248
    interface Port-channel3
    description Aruba Controller Uplink
    Thank you....
  • 2.  RE: can you put a 7005 in a port-channel%3F
    Posted Nov 07, 2016 07:13 PM
    It doesn't look like you added any interfaces to your port channel 1 on the Aruba Side...
  • 3.  RE: can you put a 7005 in a port-channel%3F
    Posted Nov 08, 2016 08:49 AM
    Sorry, cpoied the wrong interface config, yes I do have it part of the port channel, after further troubleshooting, found out I was hitting a bug on the cisco code I was running, ended up uprading and is now working.
