Can you schedule a Aruba 3600 Controller to reboot on a weekly / monthly basis
  • 1.  Can you schedule a Aruba 3600 Controller to reboot on a weekly / monthly basis
    Posted Apr 30, 2014 07:50 AM
    #3600
  • 2.  RE: Can you schedule a Aruba 3600 Controller to reboot on a weekly / monthly basis
    Posted Apr 30, 2014 08:06 AM
    There is nothing built into ArubaOS with that functionality, no.
  • 3.  RE: Can you schedule a Aruba 3600 Controller to reboot on a weekly / monthly basis
    Posted Apr 30, 2014 09:46 AM
    You may be able to achieve this with a script and a MRV using its power adapter. This would serve the dual purpose of adding serial console access to the controller.
    Mike
  • 4.  RE: Can you schedule a Aruba 3600 Controller to reboot on a weekly / monthly basis
    Posted Apr 30, 2014 09:54 AM
    mldickson,
    Would you care to provide or point to an example?
  • 5.  RE: Can you schedule a Aruba 3600 Controller to reboot on a weekly / monthly basis
    Posted Apr 30, 2014 11:17 AM
    The MRV (www.mrv.com)  LX series console server provides OOB serial connectivity. We use model LX4016-T but there's a huge array of density options (the LX-1000T 4-port is their smallest option, I believe).
    Power management is achieved by adding their companion power controller, the MRV LX 5260. Commands sent from the console server can be pushed to the power controller. I belive we performed scheduled power cycling a while back using SNMP scripts. I'd have tio check. It looks like newer version of MRV firmware will allow scheduled "device-under-test" functionality and possibly other built-in scheduled power cycling options.
