Can you simultaneously support different VIA users, on the same controller, using PEAP and EAP-TLS?
  • 1.  Can you simultaneously support different VIA users, on the same controller, using PEAP and EAP-TLS?
    Posted Aug 31, 2016 10:50 AM
    We currently have a group of users authenticating their VIA access using EAP-PEAP.  We want to move them to EAP-TLS, using x.509 certs they have already been issued.  Can we configure the controller and/or ClearPass to simultaneously either/or auth mechanisms?  Would we need a different interface (and matching URL) for each, or could it all be done using the same interface and URL?
  • 2.  RE: Can you simultaneously support different VIA users, on the same controller, using PEAP and EAP-TLS?
    Posted Aug 31, 2016 10:58 AM
    Yes, you can. You just create a second set of profiles. One for each authentication method.
  • 3.  RE: Can you simultaneously support different VIA users, on the same controller, using PEAP and EAP-TLS?
    Posted Aug 31, 2016 11:05 AM
    Thanks Tim - presumably you just have to be careful to issue the right profile to the right user at the right time?
  • 4.  RE: Can you simultaneously support different VIA users, on the same controller, using PEAP and EAP-TLS?
    Posted Aug 31, 2016 11:07 AM
    The user can either select the profile themselves (common) or you can return different user roles with different policies attached based on policy in ClearPass.
