Can/Can't I or Should/Shouldn't I connect AP to PoE switch and at the same time to power suply?
  • 1.  Can/Can't I or Should/Shouldn't I connect AP to PoE switch and at the same time to power suply?
    Posted Jun 08, 2016 07:37 AM
    Question like the subject. Does it matter?
    Mariusz
  • 2.  RE: Can/Can't I or Should/Shouldn't I connect AP to PoE switch and at the same time to power suply?
    Posted Jun 08, 2016 07:57 AM
    You could, but why would you?
  • 3.  RE: Can/Can't I or Should/Shouldn't I connect AP to PoE switch and at the same time to power suply?
    Posted Jun 08, 2016 09:16 AM
    I have a couple of APs installed in hard to reach places. There is posibility to connect them to power suply there.
    If for some reason I have to change PoE switch for non PoE switch I will have working APs. Does it make sense?
    Please don't care my English, I know I'm not very good :-) And I don't want to be unkind, if I am, I'm sorry, it the result of my knowledge of English :-(
  • 4.  RE: Can/Can't I or Should/Shouldn't I connect AP to PoE switch and at the same time to power suply?
    Posted Jun 12, 2016 02:52 PM
    sure makes sense in that case. giving yourself options. hopefully you can easily turn the external power off for a hard reset if it is needed.
  • 5.  RE: Can/Can't I or Should/Shouldn't I connect AP to PoE switch and at the same time to power suply?
    Posted Jun 17, 2016 01:40 AM
    in this case way you do not use Power Injector ?
  • 6.  RE: Can/Can't I or Should/Shouldn't I connect AP to PoE switch and at the same time to power suply?
    Posted Jun 17, 2016 03:08 AM
    I thought i read that if both are connected the DC power source will be used.
