Cannot access web-management or captive portal
This thread has been viewed 48 times
  • 1.  Cannot access web-management or captive portal
    Posted Mar 02, 2018 09:43 AM
    Yesterday captive portal on our controller 7205 stopped working. I tried to login to web management and it's not working either. Tried with different browsers and computers.
    APs work with radius client's normally.
    SSH to controller works.
    Controller has been restarted.
    What should i try to get web-management (and captive portal) to work again?
    Any help would be appreciated.
  • 2.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 09:52 AM
    ssh into the controller and type "show audit-trail" to see what might have been changed.
  • 3.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 10:58 AM
    audit trail shows only one line from yesterday:
    webui[3870] 23:57: USER: Error Executing the Command.
    no earlier changes.
  • 4.  RE: Cannot access web-management or captive portal
    MVP EXPERT
    Posted Mar 02, 2018 09:55 AM
    What version of ArubaOS are you running? Is the CWP/GUI secured with a certificate? The default certificate which has been shipped with controllers has been revoked so this maybe an issue.
    Do you see any issues when running the below command?
     # show web-server profile
    Have you tried restarting the service as well?
    #process restart httpd
    Has there been any firewall policies been applied to the management ports on the controller?
  • 5.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 11:16 AM
    ArubaOS 6.5.3.0
    Seems to be ok to my understanding...
    Web Server Configuration
    Parameter                                          Value
    Cipher Suite Strength                         high
    SSL/TLS Protocol Config                    tlsv1 tlsv1.1 tlsv1.2
    Switch Certificate                                default
    Captive Portal Certificate                    wlan2
    IDP Certificate                                    default
    Management user's WebUI access method              username/password
    User absolute session timeout <30-3600> (seconds)  0
    User session timeout <30-3600> (seconds)           900
    Maximum supported concurrent clients <25-320>      75
    Enable WebUI access on HTTPS port (443)            false
    Web Skype4B Listen Protocol/Port Config            N/A
    Enable bypass captive portal landing page          false
    Exclude Security Headers from HTTP Response        false
    # show web-server statistics
    Error in fetching statistics, Web Server is not respoding
    I've tried to restart httpd and doesn't seem to help. (also restarted controller)
    Captive portal has valid certificate from public ca.
    To be honest i'm not sure about webgui certificate.Only logged on using ip-address.
    No firewall policies on management ports.
  • 6.  RE: Cannot access web-management or captive portal
    MVP EXPERT
    Posted Mar 02, 2018 11:25 AM
    Looks like the Web Server has stopped responding.
    This is still the same issue after a reboot and a httpd service restart? This might be a known issue with the OS you are running. Maybe speak to TAC or check the release notes for a possible fix.
  • 7.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 11:30 AM
    ArubaOS 6.5.3.0
    Restarted controller.
    Restatred httpd service multiple times.
    Issue remains.
  • 8.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 11:40 AM
    How long ago did you change the Captive Portal Certificate?
    Try changing it back like this:
    config t
    web-server profile
    captive-portal-cert default
    Nevermind.  Please open a TAC case.
  • 9.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 12:03 PM
    Cert was installed 8-9 months ago.
    I tried changing to default and restarted httpd but issue still remains.
    Thank you for the help anyway.
  • 10.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 12:40 PM
    What do you see in the browser when you try to browse to the controller's web page?
  • 11.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 12:49 PM
    IE:
    "This page cannot be displayed"
    CHROME:
    "This site cannot be reached"
    ERR_CONNECTION_REFUSED
  • 12.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 12:52 PM
    What is the URL?  Does it redirect to https://<ip address>:4343/URL?  What is the URL without the ip address that it fails on?
  • 13.  RE: Cannot access web-management or captive portal
    Posted Mar 02, 2018 01:00 PM
    i've tried with both:
    and
    Both give same error.
    URL used to work with https://<ip address>
    (i had it bookmarked on management workstation)
    If i understood your question...
  • 14.  RE: Cannot access web-management or captive portal
    Posted May 31, 2018 06:26 PM
    Hello
    Getting same issue as described. Restarts do not fix.
    (hostname) # show web-server stat
    Error in featching statistics, Web Server is not responding
    Did OP come up with a solution?
  • 15.  RE: Cannot access web-management or captive portal
    Posted Jun 01, 2018 02:29 AM
    Controller firmware update solved the problem.
