The number of SSIDs supported differs per AP. Most APs should support 16 BSSIDs per radio, with exception of the older APs like 104, 105, 175, that support 8 per radio.
Please note that you should not have that many SSIDs because the SSID broadcasts (also hidden SSIDs do broadcasts)
will fill up the available airtime.
Original Message:
Sent: Sep 13, 2022 07:24 AM
Subject: Cannot advertise 9th SSID - AOS 6.5
Dear Experts,
One of my customer is using 7210 controller with AOS 6.5. They are already advertising 8 SSIDs but when they configure the 9th SSID, its not broadcasting. Assignment to AP group is done as with previous SSIDs but its not being broadcasted.
any ideas? i thought there is no limit or even if there is a limit it was supposed to be 16 i guess.
