Cannot Block IPv6 Traffic
  • 1.  Cannot Block IPv6 Traffic
    Posted Nov 07, 2017 12:39 PM
        In my IAP225, I am trying to block IPv6 traffic on a specific network. My goal is to allow only IPv4 traffic and block all ipv6 traffic going in the network. To achive this, I have created a network profile and associated a ACL rule to the profile. The acl rule to deny ipv6 traffic is given below.
        84:d4:7e:c6:d5:74 (Access Rule "TEST") # rule any any match ipv6 any any deny
    However, this is not working. I can still send ipv6 traffic(ping traffic) over the network.
    Set-up details: I have a set-up with 2 Aruba AP's and each WAP is connected with one Client(laptop's). The Laptop's are configured with IPv6 addresses(default link local address).With the above ACL rule configured in Aruba, I expect, all IPv6 traffic should be dropped however, that is not happening. I can still reach other client in the network via ping.
    Aruba WAP Type    : IAP225
    Firware Version    : 6.5.0.0-4.3.0.0_56428
    Please let me know is there any way to block only IPv6 traffic?
    Thanks in advance.
    -Shiva
    Attaching the the complete network configuration and the ACL rule for your reference.
    ACL Rule:
        wlan access-rule TEST
         index 3
         rule 224.0.0.0 240.0.0.0 match any any any deny
         rule 172.19.248.0 255.255.255.248 match any any any permit
         rule 172.19.248.0 255.255.252.0 match udp any any permit
         rule 172.19.248.0 255.255.252.0 match any any any deny
         rule any any match any any any permit
        wlan ssid-profile TEST
         enable
         work-without-uplink
         index 1
         type guest
         essid Test-SSID
         opmode opensystem
         max-authentication-failures 0
         vlan 4092
         rf-band all
         captive-portal disable
         dtim-period 1
         inactivity-timeout 120
         broadcast-filter unicast-arp-only
         deny-inter-user-bridging
         g-min-tx-rate 36
         a-min-tx-rate 36
         a-basic-rates 36,48,54
         a-tx-rates 36,48,54
         g-basic-rates 36,48,54
         g-tx-rates 36,48,54
         supported-mcs-set 5,6,7,13,14,15,21,22,23
         vht-supported-mcs-map "7,8,9,-"
         blacklist
         dmo-channel-utilization-threshold 90
         multicast-rate mcs15
         local-probe-req-thresh 0
         max-clients-threshold 45
         dot11k
         dot11v
  • 2.  RE: Cannot Block IPv6 Traffic
    Posted Nov 30, 2017 01:55 PM
    Thanks Vijay for helping me in this issue.
    The CLI indeed has an option to block to block IPv6 traffic while configuring the ACL rules. Use the below options based on the interface you are using.
    1. Use 'v6-deny" if you are using GUI
    2. Use "raw" option in CLI.
    A sample ACL rule is given below.
          rule any any match raw any any deny
    Shiva
