Comware
  • 1.  Cannot change my management vlan ID
    Posted Oct 25, 2017 03:39 AM
    Hello.  I have a problem changing my switch's management vlan ID. Whenever I want to apply the setting the page keeps loading forever. I also noticed that web management on chrome is missing a few buttons.
    I am using hp 1820-24g switch j9980a with it's latest firmware.
    Any ideas about my problem?
    #vlanid
    #VLAN
    #bug
  • 2.  RE: Cannot change my management vlan ID
    Posted Oct 27, 2017 06:01 AM
    Was your management host - from which you're initially managing your Switch - moved to a VLAN Id 2 untaggeed port (from being connected to a VLAN Id 1 untagged port) or, at least, moved on a port that is untagged on VLAN Id 1 and tagged on VLAN Id 2 so it can reach VLAN Id 2 Management IP just after the change? or am I missing anything else?
    Edit: WAN Routing- no WAN Routing issue here - is clearly wrong as HPE Community's thread category...better to ask moderator to move this thread into the correct category at Web and Unmanaged here.
  • 3.  RE: Cannot change my management vlan ID
    Posted Nov 02, 2017 07:02 AM
    After I applied the changes made to my management vlan ID port I did try connecting to the newly assigned port, It did not make any difference - loading was stuck in a loop. I also tried wating for changes by staying connected to the default port for more than 10 minutes.
    Whatever I tried the loading was stuck in a loop. I tried both tagged and untagged ports, too.
  • 4.  RE: Cannot change my management vlan ID
    Posted Jan 30, 2019 01:59 PM
    I have the same problem. Has anyone discovered a solution? Thank you very much.
