cannot change to AP mode
  • 1.  cannot change to AP mode
    Posted Jul 16, 2015 06:07 AM
    I have 2 ap 205 connect to controller 7010 using 6.4.xx
    I failed to change the aps to AP mode when I choose HK as country zone
    but it successfully to do that if I choose US.
    I have search for some reference about this issue and it seem caused by the hardware restricted problem.
    here is the result of the command #show country
    (Aruba7010) #show country
    Country: US
    Model:Aruba7010
    Hardware:Unrestricted
    Is there any advise for this to change the aps to AP mode with choose HK as the country zone?
    Many Thanks
    #AP205
  • 2.  RE: cannot change to AP mode
    Posted Jul 16, 2015 06:24 AM
    You can't as the controller is in the US regulatory domain.
    I guess that the APs are flagged as E which means " E = Regulatory Domain Mismatch"
    Regards
    Borja
  • 3.  RE: cannot change to AP mode
    Posted Jul 16, 2015 09:24 PM
    Is that mean my APs are in wrong country?
    And what I need to do to fix that?
    Regards
    Alvin.
  • 4.  RE: cannot change to AP mode
    Posted Jul 17, 2015 12:28 AM
    HI,
    You have only choice of reconfiguring the existing Controller with HK country zone. how about other APs ? or this is any new deployment ?
    bast practice :
    1. Take flash back up of all the controllers or Master
    2. Reset the controller to factory
    Write erase ( Do not use write erase all, it will remove config along with License )
    3. Configure controller initial setup and select HK as the Country
    4. Configure the controller-ip as required
    5. restore the flash-backup.
    Please feel free for any further help on this.
  • 5.  RE: cannot change to AP mode
    Posted Jul 17, 2015 12:41 AM
    This is a new deployment, so I have tried factory reset already.
    Is there any idea? or am I need to do the same thing on the APs.
    Many Thanks
  • 6.  RE: cannot change to AP mode
    Posted Jul 17, 2015 12:49 AM
    HI,
    We do not have any other way to get it done. as per your information, the controller is not US restricted so you should be able to change the country code during the initial setup.
     can you share the output of "show ap database" and "show ap-debug <count>" will give some more information to understand the issue.
    please feel free to comeback with the required information.
  • 7.  RE: cannot change to AP mode
    Posted Jul 21, 2015 05:05 AM
    Thanks for help, here the command:
    (Aruba7010) #show ap database
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    04:bd:88:c1:97:4c default 205 192.168.1.18 Down 2 192.168.1.140 0.0.0.0
    04:bd:88:c1:97:74 default 205 192.168.1.69 Down 2 192.168.1.140 0.0.0.0
    04:bd:88:c1:97:8a default 205 192.168.1.169 Down 2 192.168.1.140 0.0.0.0
    04:bd:88:c1:9c:68 default 205 192.168.1.110 Down 2 192.168.1.140 0.0.0.0
    04:bd:88:c1:9c:9e default 205 192.168.1.91 Down 2 192.168.1.140 0.0.0.0
    04:bd:88:c1:9c:a8 default 205 192.168.1.21 Down 2 192.168.1.140 0.0.0.0
    04:bd:88:c1:9c:dc default 205 192.168.1.59 Down 2 192.168.1.140 0.0.0.0
    04:bd:88:c1:9c:de default 205 192.168.1.47 Down 2 192.168.1.140 0.0.0.0
    04:bd:88:c1:9c:ec default 205 192.168.1.37 Down 2 192.168.1.140 0.0.0.0
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
    I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
    X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
    R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
    c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
    u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
    M = Mesh node; Y = Mesh Recovery
    Total APs:9
  • 8.  RE: cannot change to AP mode
    Posted Jul 18, 2015 04:15 AM
    Alvincy
    sounds like you are on too old code or have an outdated regualtory info.
    please send output of:
    show version
    show ap regulatory
    show ap allowed-channels country-code hk ap-type 205
    you may also try upgrading to latest 6.4.2.x or 6.4.3.x and/or upgrading your regulatory file from the support site (software -> DRT)
    regards
    -jeff
  • 9.  RE: cannot change to AP mode
    Posted Jul 21, 2015 05:06 AM
    Thanks for help. here the command output
    (Aruba7010) #show version
    ArubaOS (MODEL: Aruba7010), Version 6.4.1.0
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2014, Aruba Networks, Inc.
    Compiled on 2014-06-12 at 03:48:45 PDT (build 44233) by p4build
    ROM: System Bootstrap, Version CPBoot 1.0.2.0 (build 43722)
    Built: 2014-05-13 10:04:08
    Built by: p4build@re_client_43722
    Switch uptime is 5 days 10 minutes 32 seconds
    Reboot Cause: Power Cycle (Intent:cause:register ee:ee:8000)
    Supervisor Card
    Processor (XLP208 Rev B0 (Secure Boot) , 800 MHz) with 3736M bytes of memory.
    32K bytes of non-volatile configuration memory.
    1936M bytes of Supervisor Card system flash.
    (Aruba7010) #show ap regulatory
    Regulatory Version :1.0_44226
    (Aruba7010) #show ap allowed-channels country-code hk ap-type 205
    Allowed Channels for AP Type 205 Country Code "HK" Country "Hong Kong"
    PHY Type Allowed Channels
    802.11g (indoor) None
    802.11a (indoor) None
    802.11g (outdoor) None
    802.11a (outdoor) None
    802.11g 40MHz (indoor) None
    802.11a 40MHz (indoor) None
    802.11g 40MHz (outdoor) None
    802.11a 40MHz (outdoor) None
    802.11a 80MHz (indoor) None
    802.11a 80MHz (outdoor) None
    802.11a (DFS) None
  • 10.  RE: cannot change to AP mode
    Posted Jul 21, 2015 05:45 AM
    hi Alvincy
    please upgrade to 6.4.2.x latest or 6.4.3.x latest - the code you are running predates the approvals for HK.  I am advising against just upgrading the DRT, 6.4.1.0 is relatively ancient code these days.
    regards
    -jeff
