Cannot Configure VLAN on Aruba 620. Please help
  • 1.  Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 13, 2013 11:51 PM
    We have an aruba 620 controller with one(1) unit Access Point(AP 105). The problem that im facing right now is I want to reconfigure the controller to fit our new setup. Currently our aruba controller is connected to existing setup which is
        internet
        router
        |   (10.118.10.0/24)
        /              Aruba 620 ------------------>AP105
                                                            firewall            (10.118.10.10)              (10.118.10.15)
                                                        (vlan20,30)
                                                   Manage Switch
    Firewall external IP(10.118.10.55)
                    Internal IP(10.65.10.100)
    VLAN 20 (10.65.1.0/24)
               DHCP Server(10.65.1.3)
    VLAN 30 (192.168.10.0/24)
    1. Currently the setup is from router to Aruba and its working well.
    2. I added the firewall so I can create another VLAN and have multiple SSID.
    3. Currently I was able to add the SSID(LAN and Guest) but when I check its not getting any IP address from our DHCP server
    From router to aruba(port is connected to Port 4 as access port. Port 0 is connected to AP as trunk) now from my manage switch(port 23 as trunk) I connect to Aruba port 7(as trunk) but im not getting any IP address from our DHCP server( 10.65.1.3). Do I need to create a route from Aruba or what I need to configure? Thanks.
    Please help.
  • 2.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 14, 2013 02:20 AM
    Hi,:smileyhappy:
    You shold define a native vlan.*your DHCP vlan *
    In the Aruba Controller:
    Go to Configuration/Ports - and choose the naitve vlan in the aruba controller (your dhcp vlan)
     Let us know if it's solved your issue.
    me
    BTW:
    *Untag naitve vlan on your bb/core switch  (if using diffrent vlan numbering in the aruba controller) *
  • 3.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 14, 2013 09:01 AM
    Hi Moderator,
    I will check again tomorrow. I will let you know the outcome. Sure I will give you thumbs up once this will be solved. :)  Thanks.
  • 4.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 14, 2013 11:14 PM
              After changing to the suggested, I cannot see the SSID. Please refer below screenshot config.
    Currently, there are two trunks, port 0(connected to the AP105) and Port 7(connected to the manageable switch)
  • 5.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 15, 2013 02:00 AM
    1. In the ssid profile ..did u choose working mode- tunnel / vlan 20?
    2. does the vlan's numbers are tagged the same in your network and on the controller?
  • 6.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 15, 2013 02:01 AM
    btw:  y did u screenschoot the uplink? it's not needed configuration for what u are looking to achive?
  • 7.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 15, 2013 02:02 AM
    and also...be sure that the trunked port is trusted....(on all the vlan's)
  • 8.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 15, 2013 03:50 AM
    I have just restarted the controller, now I can see the SSID being broadcast but still cannot connect to the dhcp server
  • 9.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 15, 2013 04:57 AM
    ok...and in the AAA profile which Access rules are u using?
    please do some screenshots
  • 10.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 15, 2013 05:36 AM
    here is the AAA Profile. Thanks
  • 11.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 15, 2013 05:38 AM
    I can see that you are doing 802.1x auth - right?
  • 12.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 15, 2013 03:29 PM
    can you provide,
    show ap essid ( as you mentioned the ssid is not broadcasting)
    show profile-errors
  • 13.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 04:18 AM
    seems that trunking is not working. What I did is, I change the port 6 as accessport  for VLAN is 20. It works. The SSID is working with my external DHCP. Now, I do the same on port 5 to use for VLAN 30 but it doesnt work. Any advise? thnks
  • 14.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 05:10 AM
    • Are u trunking - and using the same vlan tags?
    • can u printout your port config of all the trunk port u configured in your aruba please
  • 15.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 08:49 AM
    This is the Port config on Port 0 where in my AP105 is connected.
    This is the config on my Port6 where in my VLAN 20 is connected. This is working.
    This is the config on my Port6 where in my VLAN 30 is connected. This is not working. SSID is broadcast but no IP address from my DHCP server.
  • 16.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 08:50 AM
    sorry the last image should be this one.
  • 17.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 09:00 AM
    OK
    OK
    lets do here some order.
    You dont need to trunk the port that your AP-105 is sitting on..it's only need to be able to get an IP and to establish GRE tunnel in front of the controller.
    (all the need vlan's - you will choose to transmit on air-via ssid will arrive to the AP via the GRE tunnel from one vlan...)
    Next...
    From your screenshots.i can understand that you got two diffrent other port - one for vlan20 and one for vlan30 both of them configured as access ports.
    can u confirm that on vlan30 - u getting resposne from the controller on (when testing ping from other equitment to the ip of the controller on vlan 30 192.168.10.99)
    configure another port as access to vlan30 and connect your laptop to it...check if u reciving ip address from it - if not your vlan30 isnt configured right (sub or DHCP)
     update me if when 1 port with vlan30 is connected to your backbone (vlan30)  and one to your laptop (both access) - if you gettning an ip.
    me
  • 18.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 09:01 AM
    I dont want the trunking anymore. Its make more complicated. I will be make it simple. 1 SSID and 1 Vlan 1Aruba port.
  • 19.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 09:05 AM
    from my VLAN 20, I get response from my DHCP server
    from my VLAN 30, I don't get response from my DHCP server.
    I tried taking out the cable and connect to my laptop(straight from my switch), I can get IP Add, for both
    VLAN 20 and VLAN 30
  • 20.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 09:10 AM
    so - test with access role / AAA profile for both ssids.. check that u allowing users getting an IP (DHCP services) on the first role.
  • 21.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 09:21 AM
  • 22.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 16, 2013 09:26 AM
    * i sent u a private msg - please read it*
    it's a guest network - so why 802.1x?! and also...
    can u please connect to this ssid (and printout - the clients windows from the aruba)
  • 23.  RE: Cannot Configure VLAN on Aruba 620. Please help
    Posted Jul 17, 2013 03:21 AM
    I love this guy(kdisc98). Im troubleshooting this issue for quite sometimes, but he was able to make it work in minutes.
