I used the web interface to upload new firmware. The switch rebooted now I cannot even connect my console cabel( Which I personally have never done on this switch). I attempted to factory reset but I do not think it took... What can I do? This is in a lab evnvironment but I need to get to it... I am using a standard console cable which I use on other swtiches. I am using hyperterm. Not sure ,.Please help
Hy hallcarr_addon
Do you have the right console configuration?
Speed: 9600
Data bits: 8
Stop bits 1
Parity: None
Can you ping the Swtich? Did you reboot the Switch again?
